System folder
mikaela.rf.gd
Could you please delete the system folder in my root folder. Seems like I accidentally set the wrong permissions. And now I can’t reinstall AbanrtCart again.
this can happen
have you tried deleting the directory or changing the permissions using an ftp program like filezilla ?
if this fails then theres no chance to delete it, you’ll just have to ignore the problem
well you could delete that website completely and then recreate it
this is probably the only way and is what I had to do once when I made the same mistake
