Hello @Admin ,
I have an issue with MX entries for my subdomains in VistaPanel.
- The subdomain that was created automatically when I started the hosting shows up in the MX Entry section, and I can modify its MX Entry.
- However, the **subdomains I created later in same user account ** do not appear in the MX Entry section, so I am unable to set up MX Entry for them.
If_user1234 > main subdomin = its available to change Mx entry
If_user1234 > main subdomin > additional subdomin = its not available to chage Mx entry ?
Can you please check why this is happening? Also, is there a way to manually add MX Entery for my additional subdomains?
