SSL working on phone, but not on desktop
Username: epiz_30073983
URL: https://shinybuilds.ml
In my last topic I said that the ERR_SSL_PROTOCOL_ERROR error was fixed. Turns out that I was checking the website on my phone and not the computer. The website on phone works good, but on computer its displaying me the error. I’m using cloudflare flexible setting. I may have to wait 24-72 hours, because the nameservers maybe didnt update yet I think.
I think that the name servers didn’t change yet, so time will tell.
try again, it may have fixed the redirecting problem
ssl works
It working, and so is HTTPS redirection. If it’s not for you, you need to clear your cache.
Thank you! Also had to clear the cache from my other browsers to fix it.
DNS changes can take up to 72 hours to be visible. If 72 hours have not passed yet, please just have patience. 99% of the time it’s some cache issue and it will fix itself.
