SSL problem. The URL looks like it is blocking bots
Hi, everybody. I hope someone can help me.
I have tried to configure an ssl certificate from zerossl.com and sslforfree.com and in none have I been able to.
For both cases I generated the key/csr from CPanel → SSL/TLS of infinityfree. The results are as follows
zerossl:
I download and upload the files to the folder
htdocs/.well-known/acme-challenge
and throws me the next mistake:
ERROR:
Invalid response from http://edutrack.ml/.well-known/acme-challenge/dYv-n9QJBzk-T4SS6jwwuIfShzsH99jc_HqriFq9KCQ: “<script type="text/javascript" src="/aes.js" >function toNumbers(d){var e=\[\];d.replace(/(…)/g,func”
Full Error: { “type”: “http-01”, “status”: “invalid”, “error”: { “type”: “urn:ietf:params:acme:error:unauthorized”, “detail”: “Invalid response from http://edutrack.ml/.well-known/acme-challenge/\\_E8ImLrtqLjdTDNqjWz1WFLJC\\_NR8kg2RybB49AnFdQ: \"\\u003chtml\\u003e\\u003cbody\\u003e\\u003cscript type=\\\\"text/javascript\\\\" src=\\\\"/aes.js\\\\" \\u003e\\u003c/script\\u003e\\u003cscript\\u003efunction toNumbers(d){var e=\[\];d.replace(/(…)/g,func\"”, “status”: 403 }, “url”: “https://acme-v02.api.letsencrypt.org/acme/challenge/b088lXKyeI8h9MRw3PmJX1HNnFtKP2d7bwRQ0i5YDrE/9508502624”, “token”: “\_E8ImLrtqLjdTDNqjWz1WFLJC\_NR8kg2RybB49AnFdQ”, “validationRecord”: \[ { “url”: “http://edutrack.ml/.well-known/acme-challenge/\\_E8ImLrtqLjdTDNqjWz1WFLJC\\_NR8kg2RybB49AnFdQ”, “hostname”: “edutrack.ml”, “port”: “80”, “addressesResolved”: \[ “185.27.134.130” \], “addressUsed”: “185.27.134.130” } \] }
How can I configure it properly?
Cannot use or have problems using Let’s Encrypt or sslforfree.com
You can use Cloudflare instead, also there’s a way to use these free certificates, but it should go through Cloudflare too…
Thank you so much it seemed to work.
