SSL not working
Blog.coozywana.ga
The connection for this site is not secure
www.blog.coozywana.ga uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Hide details
Unsupported protocol
The client and server don’t support a common SSL protocol version or cipher suite.
You need to set your Wordpress url to https without the www subdomain for this error to go away.
But last time it worked
Please share your Cloudflare SSL settings
Please note that Cloudflare’s Universal SSL only works for first level subdomains. So blog.coozywana.ga, forum.coozywana.ga and shop.coozywana.ga will work, but www.blog.coozywana.ga, eu.shop.coozywana.ga, etc. will not.
This is because Cloudflare uses a wildcard SSL certificate for your base domain coozywana.ga, and wildcard SSL certs only work for direct subdomains.
You could disable Cloudflare on the second level subdomain and install an SSL certificate on our hosting directly (you can request an SSL certificate that protects both blog.coozywana.ga and www.blog.coozywana.ga). But if I were you, I would just not use the domain www.blog.coozywana.ga and publish the blog on blog.coozywana.ga instead.
