SSL not found
https://www.electrocred.com.ar/sorteoninez
ERR_SSL_PROTOCOL_ERROR
My domain electrocred.com.ar points to 185.27.134.216 (verified on dnschecker). The Let’s Encrypt certificate (expires 2026-12-20) shows as installed, but the Live SSL Status says “Not Found”, SSL Labs says “Failed to communicate with the secure server”, and the browser shows ERR_SSL_PROTOCOL_ERROR. Over http the site loads, but without its resources (images, styles, etc.). The site runs on WordPress. Could you please check whether the certificate was properly installed on the server?
SSL labs often has problems with InfinityFree hosting, I think some of it’s checks are blocked by the security system that blocks non-browser connections. If it shows secure in your browser, then that proves the SSL is working correctly
I can’t access your site for some reason (I get the error " www.electrocred.com.ar unexpectedly closed the connection.") so I can’t offer much advice.
Hi Dan, thanks for the quick reply and for testing it.
Good to know about SSL Labs. The error also shows up in regular browsers, though: Chrome shows ERR_SSL_PROTOCOL_ERROR on https://electrocred.com.ar, so it’s not just the SSL Labs check failing.
Here’s what I’ve checked so far:
  • DNS points correctly to my account IP (185.27.134.216), verified on dnschecker.
  • In the client area, “Installed SSL Status” shows the Let’s Encrypt certificate as installed (expires 2026-12-20), but “Live SSL Status” (and Step 5: Verify Installation) says “Not Found”.
  • Over http:// the site loads, but without images and styles, since WordPress requests those over https.
  • The site runs on WordPress, and I can’t open the admin panel because it redirects to https.
I also noticed several IP outages reported on the status page today, so I’m not sure if that could be related.
Since you also get “unexpectedly closed the connection”, it looks like the server isn’t serving the certificate over HTTPS. Is there anything else I can check on my side, or does this need to be looked at on the server?
Thanks!
Or maybe not. SSL handshake does not go through the security system for obvious reasons. I tested on my own free subdomain and got this. Now custom domains do have the intermediate certificates missing but the test failing entirely is still a problem.
Hi Meishin, thanks for testing this on your own domain.
To clarify, the error isn’t only in SSL Labs. Regular browsers also fail on https://electrocred.com.ar with ERR_SSL_PROTOCOL_ERROR, and dan3008 got “unexpectedly closed the connection” when he tried to open the site.
Quick summary of what I’ve checked:
  • DNS: both electrocred.com.ar and www point to my account IP (185.27.134.216), and there are no AAAA records.
  • In the client area, the Let’s Encrypt certificate (expires 2026-12-20) shows as installed under “Installed SSL Status”, but “Live SSL Status” says “Not Found”.
  • Over http:// the site loads, but without images and styles.
You mentioned that custom domains are missing the intermediate certificates. Is that a known issue on the hosting side? And is there anything I can do about it, or does it need to be fixed by the InfinityFree team?
Thanks for your help!
It is known and intentional, but it definitely does not make your website not accessible at all. Your website is probably having some server side issues, but this means that you need to wait for Admin.
Thanks for clarifying, Meishin.
Understood. I’ll wait for an Admin to check the server-side issue.
For now, I’ll leave the configuration as it is. Thanks for your help!
Thanks for all your help!
The issue is now (apparently) resolved, and the site is working normally again. It seems the problem was on the hosting side.
Thanks again for your help and for looking into it!
I’m also hosted on this server and having the same issue still not resolved for me. Annoyingly happened just as was renewing SSL cert.
One more thing: the last thing I did before it started working again was delete the SSL certificate and create a new one.
I don’t know if that actually fixed the issue, but the site started working shortly after I did it.
I just created a new cert and still having issue so not sure that does anything?
The same here (fokides.eu). Issued a new certificate (Let’s Encrypt), installed it but still its status is “not found.” Also, when trying to connect through multiple browsers, I get “fokides.eu unexpectedly closed the connection.” So, the issue is far from being resolved (at least for me).
