SSL not able to verify
valentine-aarya.great-site.net
My SSL certificate request is not being verified. the status is still in pending state.
SSL provider → ZeroSSL
Did you install the required CNAME records?
yes. i pressed a button under add cname and it did all the requests automatically.
It may take a day or two for the records to be verified with ZeroSSL
okay thank you.
Do the CNAME records show up as being set up? If no, then please wait a few hours for DNS caching. If they do show as being set up, there will be a button that says “Request Certificate”, that does exactly what you would expect it to do.
Thankfully, that’s not true. It should take a few hours at most.
