Ssl issue
epiz_32804401 | deveroonie.xyz
SSL certificate error: The provider encountered an error verifying the DNS settings of your domain name. Please double check your nameserver settings and try again later.
i tried to make an ssl certificate. i added the dns record and IF confirmed it and requested my cert. i refreshed the page to see that error.
Are you trying to use ZeroSSL? Maybe try another one such as Let’s Encrypt if GoGetSSL.
I’m using Lets Encrypt as that is reccomended
Maybe we got rate limited from lencr. After all, they only allow 50 certs per machine per week.
What happens if you try GoGetSSL?
Maybe you should just get a self signed and use Cloudflare Full ssl.
Just some ideas :slight_smile:
Id’ve thought it would throw a different error.
I shall try this now.
Wierdly enough, retrying LEC has worked!
Great! I’m glad you were able to get it working.
