SSL/HTTPS issue with free subdomain
https://lianifynails.rf.gd/
On Android the website shows “Connection is not secure”. On iPhone it shows “Connection Error” / ERR_NETWORK_CHANGED.
The website works normally on my laptop.
InfinityFree Domain Health Check shows “No issues found.”
My domain is: lianifynails.rf.gd
Account: if0_42852753
IP Address: 185.27.134.119
The SSL certificate visible on my laptop is issued by ZeroSSL and is valid until October 29, 2026.
Could you please check the SSL/HTTPS configuration for my free subdomain and why it behaves differently on mobile devices?
I checked your website (on desktop) and it’s working fine from here, using that same ZeroSSL certificate that you saw as well on your laptop. That’s how it’s supposed to work.
We don’t do anything different there for mobile devices. Which makes me suspect that the problem is with the internet connection your phone.
The ERR_NETWORK_CHANGED code supports that. That error code means that the browser is having trouble with the network connection, which is completely unrelated to what you’re actually visiting.
A few questions that would help narrow this down:
  • Are both phones connected to the same network as the laptop?
  • Which browsers are you using on the phones?
  • If you have access to a VPN, are you able to connect if you use it on your phone?
