SSL help needed
can anyone describe step by step how to get an free SSL for infinity free hosting. I have tried several times but can’t. I have generated private key and CSR. then what is next ? I tried some free SSL signer but can’t add SSL certificate . please anyone describe the procedure . I want https:// for my domain.
Find a company who can provide you with an SSL certificate. Most companies charge money for certificates and I don’t know any free ones which work and can be used here.
Also, to add https:// before your domain, just enter your URL with https. https is enabled on all sites by default, but your browser will show a warning saying the certificate is invalid.
thanks for your response. <3
Here is a site named SSL FOR FREE provide free SSL. I tried this site for generating certificate. I provide the CSR from the CPANEL I got. then it generates the certificate . but there’s an error.
this message shown when I upload certificate ,
Forbidden
You don’t have permission to access /panel/modules-new/sslconfigure/uploadcert.php on this server.
getacert also give free ssl.
It’s your responsibility to get a valid SSL certificate. We haven’t checked and validated every possible SSL provider in the world.
I can tell you that sslforfree.com does not work with our system (they show you an error message, and you can’t upload an error message as a valid certificate).
thank you for your response .
when successfully SSL certificate installed , do I get any message ? I have pasted a certificate and press the upload button but it reloads the page don’t show any message .
thank you again . <3
Or you can try trusted 90 days trial from gogetssl.com , Ive used it before, its easy fast and secure
If your certificate was installed correctly, the certificate text should still be in the certificate box. If it is, the certificate should be installed, but you may want to use an SSL checker to verify it’s installed correctly.
Use cloudflare for your site. They automatically install ssl for free. They have everything you need to your site
thanks everyone . I have solved my problem with cloudflare.
thanks <3 <3 .
