SSl for my site
Hello everyone, one more question from the beginner.
I wondered what a SSL certificate is, and how to install it. At the moment I’m intruding free certificates.
he only resource with which I was able to figure it out is https://www.instantssl.com/free-ssl-certificate.html, I went all the way, got the archive with the ssl certificate and entered it into the appropriate field (control panel - security -SSL).
In this case, I still have not seen (https: //) before the name of my site. Or maybe this certificate is not meant for this.
Help me to understand…
You should access your site with https:// scheme. It will not appear automatically until you set force HTTPS in Cloudflare or in .htaccess
Can you describe how to do this? or share a link to the desired topic?
https://infinityfree.net/support/how-to-make-your-website-use-https/
