Ssl does not install
redmark.ml
Hi … I want to install a successfully issued SSL certificate. But it doesn’t install.
PLEASE HELP!!!
I already entered the control panel in SSL / TLS and entered the key and loaded the certificate, I did it a day ago and it remains red, it does not install. Already verify that the name servers of the domain in question are pointing to: ns1 and ns2 epizy.com. I do not know what to do. I even deleted everything I did and reissued another certificate, the exact same thing happened, it does not install.
Welcome
  1. Please don’t use caps and bold, it makes it look like you are yelling and demanding, two things that are quite rude.
  2. What do you mean by “it remains red”? What is “it”?
  3. Did you refresh the page (the SSL control panel page) and make sure the keys stay uploaded. Did you copy the entire kay and leave the CSR spot blank?
  4. Did you follow this article/video in full?
    How to make your website use HTTPS (SSL) - Docs - InfinityFree Forum
Excuse me
I use the google translator… And I have copied everything in bold.
I have done everything exactly as shown in the video. And I also checked what you told me, after doing all that I went to this forum.
I already tried all that before entering the forum to ask :frowning:
Is in red
Yesterday I had visited your website, but I didn’t find anything. After browsing it shows ads like parked domain.
Today I checked your domain hosting and I found that,
Your domain is hosted on Bodis and monetized by Bodis. Check your domain nameserver, ask your Domain Registrar.
Maybe the domain’s nameserver was not updated from your Domain Registrar side.
HOST Info
Registrar Info
Thank you so much.
I’m going to check it out, hope it works.
The DNS of the domain is indeed wrong, but the nameserver settings are OK. This seems like it’s an issue in our side: your domain name was not setup correctly in our nameservers.
One simple way to fix this is to just remove the domain name from your account and then add it again (through the Addon Domains section in the control panel). That should force the settings to be recreated.
You will need to reinstall the certificate after that, but you can just reuse the certificate that has already been created.
Excellent answer. I really appreciate it very much.
I will try to do that. I imagine that the CNAME records will also have to be reconfigured, right? I hope it works.
Once again thank you all for your help :slight_smile:
Problem solved … Thank you very much for the help. :smiley:
