SSL Certificate Stuck on “Not Ready” Despite Correct CNAME Record
https://www.praticoenvio.com.br
The SSL certificate validation page shows “Not Ready” and “No CNAME found”. It also displays the warning: “We did not detect nameservers for your domain”. The “Request Certificate” button is disabled.
My domain is praticoenvio.com.br and my website is online and working correctly.
My nameservers are:
ns1.infinityfree.com
ns2.infinityfree.com
I added the required CNAME record for SSL validation:
Record name: _acme-challenge
Destination: 64adfce1-c184-4293-84f5-bd4d8073106e.acmedns.infinityfree.net
I checked the CNAME using an external DNS checker, and the correct destination is visible.
However, the InfinityFree SSL validation page still shows “Not Ready” and “No CNAME found”.
Could you please help me identify why the SSL validation system is not detecting the record?
Thank you.
I think the “We did not detect nameservers for your domain” warning is the real problem, and the “No CNAME found” message follows from it. I can’t tell from your post why it’s happening, so I have two questions.
  1. Where did you add the _acme-challenge CNAME? Was it the “CNAME Records” section of your hosting account control panel, or at your registrar or another DNS provider? The CNAME only counts at whoever actually hosts your DNS.
  2. If you look up the NS records for praticoenvio.com.br in the same external DNS checker, what does it list? If it still shows your old nameservers, or nothing, the nameserver change at your registrar hasn’t taken effect yet.
This article says the records belong with the DNS host of your domain. With ns1.infinityfree.com and ns2.infinityfree.com, that means the “CNAME Records” section of the control panel:
It also says DNS changes take a few hours to roll out, and that the client area can flip between Ready and not ready while that happens. I don’t know whether that applies to you, because your NS lookup should settle it.
There was an issue with the DNS check for SSL certificates yesterday. That has been fixed now, so you should be able to proceed with your SSL certificate request.
