SSL Certificate Stuck at Not Ready Despite Correct CNAME DNS
https://topendmobiledetailing.com.au
DNS validation: Not Ready.
I added the required CNAME record through VentraIP on 23 October 2026.
CNAME Host: _acme-challenge.topendmobiledetailing.com.au
CNAME Destination: e8625e6d-186e-4017-96f3-cb1282fe4a62.acmedns.infinityfree.net
I have verified the DNS record using Google Public DNS and DNSChecker. Almost all DNSChecker locations return the correct CNAME destination.
The InfinityFree SSL dashboard also displays the correct Current Destination. However, the validation status remains “Not Ready”, and the “Request Certificate” button is disabled.
Does the SSL order page list a second record, _acme-challenge.www.topendmobiledetailing.com.au, alongside the one you added? And is there a “Not Ready” status next to each record, or only the first?
The article on creating the SSL CNAME records says the page shows one or two records, one for the bare domain and sometimes one for www. The Request Certificate button only enables once the page detects the records it lists. Your post only mentions the first record.
If a second record is listed, add it at VentraIP the same way and give it time to roll out.
The article also says the page can flip between Ready and Not Ready while DNS rolls out.
If only one record is listed and it still says Not Ready, tell me which nameservers the domain uses at VentraIP. The article says the CNAME records must be set up with whichever DNS provider the domain actually uses.
Hello Lemmi,
Thank you for your response.
I have checked my InfinityFree SSL certificate order page again.
There is only one DNS record listed:
There is no second DNS record listed for the www subdomain.
The required Destination and Current Destination match exactly, but the status remains Not Ready, and the Request Certificate button is disabled.
DNSChecker confirms that the CNAME resolves correctly from almost all locations worldwide.
Could you please advise what else I should check?
Thank you.
The Current Destination field clearly shows the current CNAME record, so why does the Destination say that it’s not ready?
Simple: the Current Destination is different. The value you should use contains acmedns, but your CNAME record contains acmends. So they are not the same, and that’s why the record is not accepted.
Please update your DNS settings with the right destination, and give it a few hours to take effect. Once that’s done, you should be able to request your certificate.
I am writing to express my sincere gratitude for your prompt and highly effective assistance in resolving the recent technical issue.
Thanks to your expertise and dedication, the problem was completely resolved, minimizing any further disruption to our operations. We truly appreciate your professionalism and responsiveness throughout this process.
Thank you once again for your outstanding support.
