detjyskestrygerakademi.dk
Der kan ikke oprettes forbindelse til dette website
Forbindelsen blev nulstillet.
Prøv at:
Tjekke din forbindelse
ERR_CONNECTION_RESET
It is in Danish because that’s where I live, but it basically translates to:
This site can’t be reached
The connection was reset.
Try:
Checking the connection
After the recent incident where ‘Websites hosted on IP address 185.27.134.144 are unreachable’ (which is the IP address that my site is hosted on) my SSL certificate is not working anymore and I can’t get into my site, nor my WordPress dashbord. It just shows the above error message. The SSL certificate was working perfectly before and is far from being expired, but now it has changed status from ‘Active’ to ‘Not found’. The IP issue should be resolved according to Infinityfree, at least I don’t get that warning message when I log into my Infinityfree dashboard, and my Health Check area also shows ‘No issues found!’.
For the record, the exact same issue is there when I try to open the site from the original subdomain djsa.freehosting.dev from Infinityfree that I used before I bought the custom domain that I use now.
It seems like it has defaulted back to http since the SSL is not active somehow, but since I have set the URLs to https in WordPress, I can’t even get into my WP dashboard to change it and I am effectively locked out.
Does anyone know if this is some bug that Infinityfree is working on resolving or is there something I can/should do? I’m very new to this so please bear with me if I’m missing something obviously here
