SSL certificate not working
Hi there,
i have installed SSL certificate from COMODO recently. My site is not accessing nor green pad is visible on url. What could be the reason?
Thanks!
If the certificate was installed correctly, two explanations come to mind:
  • Your browser has cached the self signed certificate. Try opening your website in private browsing mode or use an SSL checker to verify your certificate was installed correctly.
  • You’re not actually using https. Installing an SSL certificate will not automatically force everyone to use it. You can verify the https site works by entering https:// yourdomain in your browser manually and if it works, setup a redirect to force all visitors to use the https version of your website.
