Sql for website not loading
http://soreloser.infinityfreeapp.com/
I get this error…
SQL ERROR [ mysqli ]
No such file or directory [2002]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists.
Trying to load my old PhpBB forum and I used this from my cpanel DB configuration file with this info.
|MySQL DB Name|MySQL User Name|MySQL Password|MySQL Host Name|PHPMyAdmin|
epiz_28564775_sumato_phpn1
epiz_28564775
*(Your vPanel Password)
sql310.epizy.com
Into the config.php here…
<?php
// phpBB 3.0.x auto-generated configuration file
// Do not change anything in this file!
$dbms = 'mysqli';
$dbhost = 'sql310.epizy.com';
$dbport = '3306';
$dbname = 'epiz_28564775_sumato_phpn1';
$dbuser = 'epiz_28564775';
$dbpasswd = 'PRIVATE';
$table_prefix = 'phpbb_';
$acm_type = 'file';
$load_extensions = '';
@define('PHPBB_INSTALLED', true);
// @define('DEBUG', true);
// @define('DEBUG_EXTRA', true);
any ideas or help with this?
Hi and welcome to the forum
Try to correct this from your config into this
$dbms = 'phpbb\\db\\driver\\mysqli';
and probably add/edit this
$phpbb_adm_relative_path = 'adm/';
$acm_type = 'phpbb\\cache\\driver\\file';
Thank You for the reply and the help,
I did what you suggested, and waited five minutes…
“General Error
An sql error occurred while fetching this page. Please contact an administrator if this problem persists.”
Still the same.
this is how I redid the config.php
$dbms = ‘phpbb\db\driver\mysqli’;
$dbhost = ‘sql310.epizy.com’;
$dbport = ‘3306’;
$dbname = ‘epiz_28564775_sumato_phpn1’;
$dbuser = ‘epiz_28564775’;
$dbpasswd = ‘private’;
$table_prefix = ‘phpbb_’;
$phpbb_adm_relative_path = ‘adm/’;
$acm_type = ‘phpbb\cache\driver\file’;$load_extensions = ‘’;
I added $phpbb_adm_relative_path = ‘adm/’;
to a separate line, and not sure if there is an order for it to go into.
you need to have a double backslash (escape)
as I wrote in the code
try installing phbb on one of your other hosting acc via Softaculous app from control panel
and see what code are inside in original config file
