Some questions
Hi, I have some questions for my website milanobeautyplace.epizy.com
  1. The .epizy.com subdomain is a test to see how the site will work. When I put a .com.ar domain, will it work for the SSL certificate?
  2. Will the .com.ar domain work as a parked domain for the SSL certificate?
They both will work. But you must install SSl certification on your domains after you added them.
Thank you!
