Some problems with setting DNS
good day
epiz_25983761
I have no way to configure dns (CNAME,MX,TXT)
tried to find these settings in the panel, but no find…
when setting up my domain (gbdcons.com) in godaddy - I can only configure (NS1,NS2) and no more…
please help deal with this
Since you are using Infinityfree nameservers, you cannot edit or add a CNAME/TXT/MX records using godaddy. You can only edit the DNS Records if you will change back your nameservers to goddady nameservers.
thanks, I will try this solution
