Some of site is going live
scoopertroopers.free.nf
404 error on some pages
some elements and pages are loading, everything has been uploaded into htdocs, plus i have an index page and all the file permissions are 755???
is it supposed to be like this?
Iā€™m not sure whether this is the reason for your problem, but having spaces in your html file name is a bad idea. Rename files like Contact Us.html to something like Contact-Us.html (remove spaces) and check whether the issue persists.
your home link points to http://scoopertroopers.free.nf/Scooper%20Trooper.html but that page doesnt seem to exist
if you want your home page to link to the main index then just replace the link with ā€œ/ā€ or ā€œhttp://scoopertroopers.free.nf/ā€ which ever you prefer
Noooooooo, Geez I thought I had everything right
Now I have completely fried it :sob:
it looks like the index.html file is now missing or has been renamed
the default behavior is that index.html ( or index.php if you are using php ) must be present for the site to work ( unless you setup a rule in .htaccess to use an alternate file name for the homepage )
if this file is not found then you will receive a 403 error on infinityfree
