Softaculous Problem
I don’t own this domain but this is how it looks on softaculous
kfkjfgjfgjfg
Hello.
If that is the domain connected to your account, that is correct. To install the application on a different domain name, select the dropdown menu.
not have in dropdown menu
Yes you do. Click the arrow.
empty
I am having the same issue, when I go to Softaculous, it shows yuthrgefdws.com instead of my InfinityFree domain.
I just tried it and can confirm that I have the same issue too
snippet from page source shows two options in drop down menu, the weird domain and a blank entry
<select name="softdomain" class="form-control" id="softdomain" onchange="softmail();change_admin_prefix(this.value);" onblur="checkhttps('softproto', 'softdomain', false)">
<option value="yuthrgefdws.com" >yuthrgefdws.com</option>
<option value="" ></option>
</select>
Ok, this does seem to be an issue. It looks like softaculous got messed up when an update is released. iFastNet has been notified. Hopefully this will be fixed soon!
@Greenreader9 thanks
The issue are because softaculous updated from https://sv1.scriptinstall.rocks:2083 to https://sv2.scriptinstall.rocks:2083
this will be resolved soon, thank you for you patience.
I see a new jupiter theme and a 404
i think softaculousu didn’t need updates
I think it needed, but due to server config, some things might’ve got messy
still issue with The following errors were found :
The MySQL Connection could not be established.
user epiz_31727113
Softaculous has been rolled back to previous version and everything works fine.
Thanks @LauraOrchid. I can confirm that the issue has been solved. If you are still experiencing errors, try clearing your cache.
If that does not work, please create a new topic in the “Hosting Support” category.
