I’ve tried to access Softaculous today and i couldn’t get it to work.
It just says connection timed out
My account is active, and i didn’t reach the inode limit
Looks to be working fine to me.
May sound like a random question, but can you connect access the file manager?
Both use ftp so worth checking that that is working
Yes i can access the file manager
If you’re getting connection issues to Softaculous specifically, the most common cause for that is network restrictions. Softaculous is not accessed over the standard HTTPS port (443), but over a special port 2083. That port is very common for cPanel, but restricted networks (like those from schools and some companies) may block access to that port.
A quick check you can do is to see if this page loads: https://demo.cpanel.net:2083
If you see a login page, that means the port is not blocked. If you see a connection timeout error there too, it’s definitely a network restriction.
