Softaculous App Installer Problem
**My website URL is:**dblr.in
**What I’m seeing is:**loading page
I’m using this software: Softaculous App Installer
Additional information:
when i click on Softaculous App Installer it will open a new tab and not loaded any content only loading.
When you click Softaculous app installer in cPanel then what happens? Can you provide a brief description with a screenshot?
when i click on Softaculous app Installer in cPanel , a new tab opens automatically and loading the page for hours . But notthing getting loaded and the page is blank.
Slow network speed. Nothing else
No its not a speed issue . Because the speed is 10 - 15 MBPS. All other work is going good. Such as downloading and uploading
Try clearing your cookies and browsing data
Notthing happens after clearing cookies and cache . Same situation
Hmm so probably there is a system glitch…
As I can see the screenshot, the last tab is opened with Softaculous. Please close this issue
whats the solution
Open the last tab. Ok… Solution
what means with last tab . explain
Thank you For the help.The issue is solved by changing browser. Thanks Alot.
