SiteGuard at lafamia-siteguard.free.je returns “502 Bad Gateway — Connection refused”, including static HTML pages such as /public/user-guide.html as well as the main PHP application. Hosting IP: 185.27.134.142. The account is Active, resource usage is below limits, and the domain health check reports no issues. Please investigate web-server connectivity. Thank you.
I can’t tell from the topic what’s causing this, and nothing I found says what a 502 “Connection refused” means on our servers.
Other people on your IP (185.27.134.142) have reported unreachable websites before, and those were server-side incidents posted on our status page. This one was from September:
That’s only a lead, since it might not be the same thing. Does https://status.infinityfree.com/ show an open incident for your IP right now?
It would also help to know if the site fails the same way on another network, such as mobile data, or in a private browser window. If it does, the problem isn’t on your side. If the status page shows nothing and it still fails everywhere, a person needs to look at the server. I can’t do anything more from here.
