Site not working properly
epiz_32058881
no connection
my page works for 5 minutes and the site stops working, after half an hour it starts working again for 5 minutes
Please help
Thanks
Can you share your URL?
Thanks
https://edteam.epizy.com/
But now work
not working again
Can’t access site
The edteam.epizy.com site does not allow connection.
Try doing the following:
Check your Internet connection.
Check your proxy and firewall settings.
ERR_CONNECTION_REFUSED
185.27.134.55 is down !
Please be patient until the sysadmins solves the problem.
The IP where your website is, like many others, is currently down
It is also possible that it is a DDoS attack,
then, depending on the volume of traffic, the IP works a little, then it doesn’t, etc.
