[### Website URL]
The same message continues as when I was waiting for the DNS, but the server tells me that it is already active.
Good morning. I’m quite new to this web thing. It turns out I had to wait 72 hours for the DNS issue, but the website is now active. The problem is that it won’t access the index. If I add /index at the end of the name, it does. Best regards, and thank you.
I just saw this
An index.php file from another website was found
Using Site.Pro will OVERWRITE your current website. If you want to go back afterward, you will need to restore your previous website yourself.
I have another half-finished website on a different topic. The problem is with the index of the other one? Can I only have one? Is there a solution?
