My website currenttimenews.ct.ws is not loading properly.
Account: IF0_40977484
Control panel graphs are blank and site is not opening.
Please reset my resource usage and fix my website.
Thank you.
Thank you.
Thank you.
Thank you.
@CTNews Welcome to the forum, however please make a new topic.
Welcome to the forum.
As Twineee said, please make a new topic in the future rather than hijacking an existing topic. I’ve split this off for you this time.
Can you share a screenshot of what you’re seeing in your control panel, particularly this page of the client area:
Presently, your site is redirecting to suspended-domain.net which does suggest a there’s a problem. To be honest, the most likely cause is that your domain is suspended (either temporarily or permanently) for hitting resource limits or abuse. You should be able to see information about this in the client area.
If thats not the case, then this article may be able to help you:
Hello Team,
My website https://currenttimenews.ct.ws is completely down.
DNS shows NXDOMAIN and my VistaPanel graphs are blank.
This means my account is disconnected from the server.
Account ID: IF0_40977484
I did not abuse any resources. Please kindly:
- Reattach my domain
- Reset my account resources
- Restore DNS for my site
This is my news website and it is very important for me.
Please help me urgently.
Thank you.
Here is the screenshot from my client area as requested.
Account: if0_40977484
Website: https://currenttimenews.ct.ws
The site is still not opening and DNS shows NXDOMAIN.
Control panel graphs are blank.
Please reattach my domain and restore DNS.
Thank you.
can you show the domain section of your account? and the page that looks like this:
Also how recently did you set up the site? DNS propagation takes 72 hours. So while I don’t think that is the problem, it may be related
No it doesn’t. IF the domain is still showing on your dashboard, its not disconnected from the server. And if the account is missing from that section, you need to re-add it.
The screenshot you provided suggests the account is not suspended. so thats good news. But to be clear, accounts can be suspended for more than abuse. they can be suspended for too many hits, too much cpu usage ect.
Have you read the article I listed above, and followed the steps in there? 99% of website problems here can be fixed easily
You don’t actually have the subdomain currenttimenews.ct.ws.
Your website is http://curenttimenews.ct.ws/, not https://currenttimenews.ct.ws/ (single r, not two). The latter URL doesn’t work because the subdomain is not in use. If you check the domain name that’s actually assigned to your account, you’ll see it’s working perfectly.
If you would would like to use the domain currenttimenews.ct.ws instead, you can just add it to your account as an extra domain, or create a new account for it.
