Showindia.xyz is already assigned and in use.2
My website URL is: showindia.xyz
What I’m seeing is: showindia.xyz is already assigned and in use.2
error when i want to add my domain
I’m using this software:
Additional information:
Of course it’s already in use. You created an account with that domain name two days ago. That account is all good to go.
If you don’t mind me asking, why are you trying to add the domain name again when the domain is already on your account? What are you hoping to solve by doing so?
i am facing problen to install woocommecer plugin in wordpress, that is the reason why i try different account to make sure… sorry for creating multiple account
Try manual installation. Get the zip file, extract, then upload the files.
If you think it will help, you can remove the domain from your first account through the Addon Domains section. After that, you can create a new account with the same domain. You can move domains around almost whenever you want, but not use a domain on multiple accounts at the same time.
As for your WooCommerce issue, did you see an error message like the one in this article?
https://infinityfree.net/support/installation-failed-critical-error-on-your-website/
