Shell_exec() has been disabled for security reasons
I’m getting the error shell_exec() has been disabled for security reasons, I looked through the forums so yea I get I can’t call it, so how do I do what I’m trynna do?
The error shows on this line:
$values = `$displayName,$username,$password,$phoneNumber,$email`;
These variables are declared as
                    $username = $_POST["username"];
                    $password = $_POST["password"];
                    $phoneNumber = $_POST["phoneNumber"];
                    $email = $_POST["email"];```
If you cannot use shell_exec() due to security restrictions, you need to find an alternative approach to achieve your desired functionality. From the code snippet you provided, it appears that you are attempting to create a comma-separated string of values. Instead of using backticks (```) for shell execution, you can create the string directly using PHP.
To create the comma-separated string, you can use PHP’s implode() function, which joins elements of an array with a string (in this case, a comma). Here’s how you can modify your code:
// Assuming these variables are already defined as you mentioned in your code:
// Create an array of values
$valuesArray = array($displayName, $username, $password, $phoneNumber, $email);
// Convert the array into a comma-separated string
$values = implode(",", $valuesArray);
Now, the $values variable will contain the comma-separated string of values, and you can use it as needed in your application.
Also, in the code snippet you provided, the variable $displayName is not defined. I simply used that as a filler. Make sure to define it before using it in your array.
By using implode(), you avoid the need for shell_exec() and achieve the same result of creating a comma-separated string. This approach is safe and does not rely on executing shell commands, making it compatible with many server configurations.
EDIT:
I am very limited as to how much help I can provide you on the coding side of things, as I believe this forum is designed for web and/or domain functionality assistance and the like, rather than coding directly.
You cannot. Consider upgrading to premium hosting?
Okay array does work for this particular thing
And upgrading to premium hosting doesn’t since I’m poor af and it’s absolutely not neccesary
But in general I just gotta use $x . ‘y’ . $z instead of $xy$z, which well is annoying but it works, thank you either way, 1Truth
