Hi. I installed selfsigned ssl from Infinity panel, installed it, its green and working, but my website still show: “not secured”. Please help. thanks
Please fill out the template if you want help. What is your URL!
You have a Self Signed certificate. As it says very clearly in the client area: a self signed certificate is not trusted by web browsers. What you’re seeing is perfectly normal and expected behavior.
The solution for this is to replace your current SSL certificate with a certificate from any other SSL provider we offer. If you don’t have a strong preference for a particular provider yourself, please just choose the Recommended option. The recommended options is recommended because we think it’s the best for your domain. Please don’t go and pick a different option and then complain it doesn’t work perfectly.
appreciate it admin. Cheers
