That sounds like an error displaying your page, NOT that its been blocked.
are there any other errors in the dev console that might hint at what the issue is?)
It only happens on one specific IP address (the school’s public IP).
On every other network or device, the website works perfectly fine without any errors.
Also, there are no visible errors in the dev console (Network tab shows 200 OK, but the page remains blank only on that IP).
So it’s not a coding or site error – it’s isolated specifically to that IP.
I believe it is related to a previous incident (high traffic/spam from the school’s IP) causing a silent restriction or filtering, either by hosting or Cloudflare.
One thing I will say for 100% certain, if you were IP blocked by any hosting provider, you wouldn’t get a “200 OK” message. that would defiantly go to some kind of 403 message.
I know, can you try accessing my site https://valthorin.pp.ua/ and see if that loads for you?
Because that is also hosted with Infinity Free, if that page loads, then we can say for 100% certain that there is no block by Infinity Free.
Hello again,
I have now tested with the school IP and gathered the network request details:
POST that results in a 302 redirect.GET which returns a 200 OK status.However, the actual page displayed is completely blank, exactly like what happens with my domain https://testi-bgt.com/ from the same school network.
Important points:
Possible causes now:
Just looking at my cloudflare dashboard, it looks like Cloudflare blocked the connection.
did you see the chalange box?
Normally I wouldn’t reccomend this, but try:
or change your cloudflare set up to bypass cloudflare temporarily.
I saw the challenge box, but it was when opening your link (valthorin.pp.ua), not my own site (testi-bgt.com).
On my own site, testi-bgt.com, there is no challenge box — it just loads a blank page on the school IP.
Since Cloudflare protection is important for our site (due to previous issues), I would prefer not to disable it or switch back to InfinityFree nameservers unless there is no other solution.
Is there any other way to solve it while keeping Cloudflare active?
I’m only suggesting disabling cloudflare temporarily to try and eliminate that as the cause of the problem. I appreciate how important it is, I use it on my site because of having had multiple DDOS attacks against my own sites.
I’ve just tried adding a custom allow rule, using your schools IP address (185.188.217.37) to my cloudflare. I’m also bypassing cache temporarily to see if that helps.
Can you try my page again to see if that lets you access it?
Thank you for trying that!
I just tested your page again (valthorin.pp.ua) from the school IP, but unfortunately it still shows a blank page.
No challenge box, no error message — just completely blank, same as before.
Also, about disabling Cloudflare temporarily:
I totally understand your point and your experience with DDoS attacks.
But since we’ve already had similar issues earlier, I would really prefer to keep Cloudflare active if possible.
If nothing else works, I will consider it later as a last option.
Unfortunately, I’ve now run out of ideas.
Hopefully someone else here will have some more ideas as to what could be causing the problem
Instead of switching nameservers, look in the sidebar of Cloudflare for the “Disable Cloudflare” link button.
This looks really weird to me, is there anything in the elements tab that could be a rendering error? Anything in the console tab? Try an incognito tab to get around any extensions / adblocks on the computer. My guess is still local firewall, but that is a very weird way to block websites.
Today I also tested the old domain (etesting.ct.ws), which is not connected to Cloudflare, and I noticed that it also loads correctly now.
Since both domains (the one protected by Cloudflare and the one directly on InfinityFree) are now working fine from the school IP,
I believe the issue was not caused by Cloudflare, but was probably a temporary block, network issue or cache problem related to the hosting provider (InfinityFree) or the school’s network.
Everything seems stable now.
Thanks again to everyone for the support and suggestions!
I’m glad to hear its all working for you now ![]()
