This site/page has used all available resources allowed for a free hosting account.
Refresh the page once the amount of resources has reduced.
We would recommend upgrading your hosting account at Our Premium Hosting, premium hosting accounts have much higher dedicated resources.
Hello. I need help identifying the source of this block.
The issue was observed on 2026-09-24, between approximately 22:45 and 22:53 in the America/Sao_Paulo time zone (UTC-3)—equivalent to 2026-09-25, 01:45 to 01:53 UTC. The warning appears simply upon opening the site or the login screen.
Checks performed:
The main site’s homepage and /login page display the aforementioned warning.
The homepage of dashboard-api-ufrn.gt.tc, under the same account, also displays the same warning.
The static file /assets/img/favicon-b.png loads normally.
The account status is “Active,” with no recorded suspensions.
The dashboard showed 273/50,000 hits, 1,069 MB/5 GB disk usage, and 4,958/80,000 inodes.
Daily CPU usage is low.
In the technical panel, RAM, I/O, and Entry Process Failures show “No data available for this graph”; therefore, I am not interpreting the empty graphs as zero consumption.
Five domains share this account. The reported hosting IP is 185.27.134.55.
Checks were spot checks; no load testing was performed. A review of the local code revealed no external queries triggered automatically upon opening the login page. It has not yet been possible to identify the specific process or domain that triggered the restriction.
Could you check for stuck PHP processes, determine which instantaneous limit is being reached, or see if there is a server-side issue? I also need guidance on identifying the specific request causing the restriction and restoring access.
First of all this is an English forum so please post in English, if you don’t speak English then please use something like Google translate. I’ve translated the post for you but please make any further posts in English.
The error you saw is because of hitting the entry process limit. The graphs will not show any metrics being overused because the entry process limit is a bit different. You will see a small spike in the EP Failure graph, but that will not go over the limit.
I’m currently test driving an AI auto responder for topics. I can see them but you can’t. It’s a bit of a hit and miss at times and I’m still working on it, but I do want to share it with you here because it’s pretty much spot-on and quite extensive.
