Redirecting you too many types
So I should order the new certificate from Infinity free and get private key and certificate and install it in cname records of cpanel(in infinity free) right?
Yes, as now self signed option is also available so you can use that to issue a certificate for at least 10 years and use it.
cname records go in cloudflare
also, you can press the request certificate button if u use infintyfree
It’s easy.
So I can instal the certificate from infinity free either in cloudflare dns or in cpanel dns or both?
put the certificate in ssl and tls in cpanel, and the cname records in cloudflare dns
DNS doesnt handle ssl
DNS = domain name system
ssl = secure socket layers
tls = transport layer security
You can install infinityfree SSL on your infinityfree account and then use full SSL from cloudflare side.
