Hello, I ran into a problem: I recently created a website on a free plan with the domain veltary.rf.gd because I wanted a separate website for this project. I also wanted to allocate two subdomains for two pages, devpanel.veltary.rf.gd and admin.veltary.rf.gd, but unfortunately I didn’t see the usual parent domain .veltary.rf.gd in the list of my domains. I also have golden-devs.rf.gd, and I can easily create subdomains with this domain there. Why?
Going by an older staff answer, you can’t create subdomains of a free subdomain like veltary.rf.gd. That would explain why it isn’t in the dropdown.
That answer says subdomains can only be created in the Subdomains menu. The only domains you can create them under are the free domains we provide and your own domains added as Addon Domains. Here’s the topic:
The Subdomains section also lets you add more free subdomains to an account, such as another name under rf.gd. Each one gets its own separate htdocs directory, so you could register two separate free names for your two pages. That’s covered in this article:
What I can’t explain is golden-devs.rf.gd. Your account already has subdomains under it, which looks like the same situation, and that article doesn’t say why it works there. Did you create those subdomains recently, or a while ago? If it was a while ago, that may be the difference. If it was recent, tell me where you picked golden-devs.rf.gd in the Subdomains dropdown.
It used to be possible to create them, but only on the domain you used while setting up your account.
This was fixed for new accounts, but not retroactively applied to older accounts.
So it does work for the account you created last year, but doesn’t work for the account you created yesterday.
As for the “why”: setting up sub-subdomains was never officially supported, but it was possible due to a bug, and we just never bothered to fix it because there was no harm in it.
Then we changed how SSL works for free subdomains, which meant that free subdomains got automatic SSL, but subdomains of subdomains could not get SSL at all anymore. And since running a website in 2026 without SSL is unacceptable, it was decided to fix the bug after all to avoid further confusion.
