Hello, I have a quick question about SSL: Why the free infinity free SSL is not trusted in all browsers? Is a problem? How can I fix? Making a SSL lookup he gives this warning
chain certs arent supported
Use Cloudflare on full SSL mode
Yeah, @greenreader9 is correct. However browsers usually fetch the chain certs from a repository. The only problem is that you can’t do speed tests using gtmetrix (since they require chain certs).
And what matters?
