Question about splitting resources vs studio editor solution
n/a
n/a
Hi, I am considering taking on this service. However I want to use it differently.
I was on another company for nearly 3 years and that relationship endly messy as they started to have real bad issues. That lead me to study how to make my site run better because 2s page loads and a plethora of “Hey look at my site” responses = “your site dont work” was all a bit much for me, not that the company cared, they happily kept my money and shut off my hosting while it is still paid til dec26. Anyway…
I ran into the idea of simply static, hosting on a cloud which is ms page load times now but now I need a place to run the wordpress editor. So basically the wordpress site entirely except for the heavy files, they all remain on the cloud and the simply static exports new content to the cloud.
I am looking at local scripts to make this easier. simply static only has to export a few files, the other 10,000 files are done.
There was an idea of splitting out the load three way, a sql host, a cloud for files and a place for the wp engine and that may be something to test down the road if it is viable. But for now, this current idea is champion.
But I want to know from you folks who run infinityfree if this whole idea or the actual split idea would be allowed on your sevices. I do not want to go to the lengths of setting it all up to find I am sonehow breaching a rule. I do not want much, certainly have no intention of wanting mass resources, cpu storage or anyhing. We have wittled it down to needing less than 1gb, easily. inc sql.
Some help would be brilliant.
Thanks
B
You need to get the premium version for your workflow, which should work, but I won’t give any definitive answer because they have some restrictions on using scripts.
The free plan won’t work, WordPress is extremely resource intensive.
Yes, using a Simply Static exported site will work perfectly fine on InfinityFree. You can also try running your WordPress installation on InfinityFree directly if you wish, but Simply Static would result in your account using little RAM or CPU power, so you’d stay under those limits. The split idea would be more problematic. As for where to run WordPress, you can use LocalWP to run it on your own computer for free.
On the contrary there are lots of sites running on InfinityFree using WordPress just fine. It’s only when you use certain resource intensive plugins like Elementor (or use a large number of plugins at once) that you run into resource issues. Of course visitors play a role too, so busier sites would still be better off taking the Simply Static route.
Contrary to what @EdwardSkunk suggests, I think I would go for your current plan @i34N70N.
Our hosting works fine for static sites, sure, but it’s not the main use case of our service. At the same time, there are services built for static sites that are faster and have more generous traffic allowances (or even provide unlimited traffic), so I wouldn’t recommend it.
Running the WordPress backend on our hosting and publishing to a static site hosting from here sounds like a great idea. You can leverage our PHP+MySQL stack for WordPress (which is where our hosting actually shines) while offloading actual web traffic somewhere else.
All the power of WordPress, a very fast site with very generous traffic limits, all by combining free services? Sounds like a pretty good setup to me!
Sorry to interrupt but I was asking infinity and indeed emailed you guys at infinity, but while I appreciated the regular users getting involved with their beliefes on what is possible here, I see admin have been kind enough to jump in and seemingly talk to/about you two getting involved and not reply to my OP.
So I am going elsewhere. Thanks but, no thanks.
Sorry that you’re unhappy with the experience you’ve had, but you do have to be aware that this is a community forum. Not a support team ticketing system.
Admin own’s InfinityFree and run’s it solo, so he can’t provide solo support to people. If you look across the other threads on this forum, you’ll often find that we help each other, and admin pops in when he’s about and free.
In this instance, I do think admin got in a muddle and thought that you were Forum-993. Since your default profile pictures are the same colour, and at a glance, its easy to make a mistake. Particularly since his answer, actually seems to be supporting your idea, just with the wrong name attached.
