Qualles.com is already assigned and in use.2
Hello,
How can i delete to domain name ? Can you assit me for find user id in there?
Thanks,
Welcome!
That means that the domain name is currently in use with another hosting provider. You will need to locate your old hosting provider and remove the domain from your account. Once you do so, you will be able to add the domain here.
so, can you see to user id? if yes, could you pls inform me?
Thanks,
Hello
I am not quite sure what you mean by “user id”. The error is because you are already using that domain on a different provider.
Your domain is already assigned to an account at byet.org. Remove from your account there.
yes but id? i dont remember it
Why would we know your username! Your account, your credentials, your responsibility. Contact support (support.ifastnet.com).
