Problems with WP and WooCommerce
Im recieving such errors using Woocommerce:
Warning : mysqli_real_connect(): (HY000/1203): User 29685334_3 already has more than ‘max_user_connections’ active connections in /home/vol5_4/epizy.com/epiz_29685334/wp.freecluster.eu/htdocs/wp-includes/wp-db.php on line 1653
Deprecated : mysql_connect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/vol5_4/epizy.com/epiz_29685334/wp.freecluster.eu/htdocs/wp-includes/wp-db.php on line 1685
Warning : mysql_connect(): User 29685334_3 already has more than ‘max_user_connections’ active connections in /home/vol5_4/epizy.com/epiz_29685334/wp.freecluster.eu/htdocs/wp-includes/wp-db.php on line 1685
User 29685334_3 already has more than 'max_user_connections' active connections
This either means that the username and password information in your wp-config.php file is incorrect or we can’t contact the database server at sql105.byetcluster.com. This could mean your host’s database server is down.
  • Are you sure you have the correct username and password?
  • Are you sure you have typed the correct hostname?
  • Are you sure the database server is running?
If you’re unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
Looks like the server is congested. Please wait.
Like the error message says: there are too many database connections from your code.
We limit the number of database connections a single database user can make to prevent a single side from overloading the database server it’s on.
WordPress with WooCommerce is quite heavy software, and many people are reporting various issues hosting it here.
