Problems with phpBB install
Username (e.g. epiz_XXX) or Website URL homebrewcumbria.co.uk
I’m trying to install phpBB via the softaculas area but when I try it says I already have one, but nothing shows up on the scripts installed only wordpress, what can i do?
If you already have one site installed on http://homebrewcumbria.co.uk, you can’t install another site on that exact same URL. If you want to use both phpBB and WordPress, you could choose to install phpBB on http://homebrewcumbria.co.uk/forum/ instead. Or create a subdomain and install it on http://forum.homebrewcumbria.co.uk.
And if you don’t want to use WordPress anymore and want to only use phpBB, you’ll need to remove WordPress first before you can install phpBB.
