What exactly happens when the POST fails? I need the HTTP status code and the response body, or the curl_error() text if no response comes back at all. Without that, “fails” could mean a refusal from OpenAI, a connection problem, or something in the script.
I searched the forum and knowledge base and found nothing saying that POST requests to api.openai.com are blocked or limited on InfinityFree. So I can’t say whether the hosting is involved. The error text should show whether the request leaves your site and what OpenAI sends back.
It would also help to see the POST code with the API key removed. Please don’t post the key itself.
Error 2 and 3 very much look like problems with your API call, not something that we as a hosting provider can influence.
It would be good to check that the API request body actually matches what you use locally. Configuration or latent bugs can result in different results which could explain the behavior. Some debug statements in your code to dump the JSON before sending it can help rule out a lot of issues.
