millions of websites use sitemap files and it works here
I don’t know why you even use .htaccess because of sitemap.xml like AddType application/xml .xml
the server takes care of that
Simply upload sitemap.xml to the root of the website (immediately in htdocs) and submit the correct URL for the sitemap file to GSC
no FileType, rewrite, etc. is necessary
It doesn’t even make much sense (cache or not), because those three links in your sitemap lead to pages that you will never edit ( terms, privacy, contact)
nor will there be a need for the crawler to come there every day to see what new content is.
when you post any code on the forum
wrap it at the beginning and end with this ```
or select it and press this button
And always make an extra line/space when you put pictures
because if it is not there, the forum cannot understand what is the picture and what is the rest of the text, so the pictures are not visible on the forum
Ah…Arabic letters sometime convert from left to right. Arabic people write from right to left and that is the reason why their browsers sometimes have the dots ¿ upside down ¿
