i deleted my .htaccess file and i cant upload it or make new one
Can you please be a bit more specific? What’s the actual issue you see?
i deleted .htaccess i cant change error pages and i want remove .php example index not index.php
You should be able to create a new .htaccess file in the htdocs folder of your website and add your own .htaccess rules to it. You can probably find rules to remove the extensions from the files somewhere on the internet.
thanks
