Problem
It can take up to 72 hours for new domains to be accessible everywhere!
4 days now and i see that + i cant join from other countrys for example greece
Please provide your site url otherwise we can’t help.
https://tenies-online.ct.ws/
I don’t have any issues visiting your website. Can you try using a different network or a VPN? It sounds like the issue might be on your end.
i use vpn to join from greece
Sorry, I don’t understand. what do you mean exactly? Did you mean you can’t visit with a VPN location from greece, or that you can’t join with or without a vpn?
i try to join with vpn from greece to my website but i cant join is down
and i have this It can take up to 72 hours for new domains to be accessible everywhere! i think the problem is this but now is the 4 days
you can’t visit with vpn from greece, but can you visit your site without a vpn? if you can’t visit with a vpn, it is probably because your vpn provider blocked it. and if you can’t visit without a vpn too, your isp or something on your end is blocking it. since you waited 4 days, i don’t think it is a dns propagation issue. you should try a different network or another vpn because infinityfree does not block access to anyone, and the issue might be on your end.
