Problem with this forum and cloudflare sec
@Admin
hello H. I ran into some problem in this forum
transparent frame from cloudflare appears requiring recaptcha
if a new topic is opened - normal popup from CF is displayed correctly
but if you reply to someone in this forum - popup is broken and splits trough page
try this
copy this below
<script type = "text / javascript"> </ script>
and paste it in the reply text field
then select it
and format it as CODE
then click preview
and watch
and also when I post this topic
JSON show up
btw. You should remove this line “Confirm Google Webmaster with HTML file”
from here https://infinityfree.net/support/javascript-error-using-api-or-mobile-android-app/
because this works
I tried reducing characters and actually this is a trigger <&/ script>
without &
otherwise I’m not able to send a post
Likely Cloudflare’s security filter sees pasting code as an XSS attempt or something like that. I will check why you get that error.
because this works
Last time I checked, it didn’t. I’ll recheck that as well. Still, DNS records are a viable alternative for which I know it works.
about webmaster tools aka search
you need to download html file again from google
even if the old one already exist and with same name
I did it for my site last year and it’s OK
even pinterest validation passes :slight_smile:
Well, as expected, your Javascript snippet triggered Cloudflare’s XSS vulnerability filter. I’ve relaxed the firewall a bit now, please try if you are still being blocked.
You are fast B)
Forum works well ! tested
I have nothing against XSS vulnerability filter.
My only problem was that I did not go through recaptcha because it was broken.
No pictures of buses, signs, roads, etc. only transparent frame with cloudflare-ray error + my IP and some text across the entire forum related to malware, so I was not able to post.
Thank you for your time H.
@OxyDac said:
You are fast B)
Disabling a firewall rule is super simple: look up an IP address in Cloudflare’s firewall log, look up the matched rule ID and disable that rule in the security system. XSS filters are normally useful, unless people are supposed to submit code snippets and the receiving applications are adequately protected.
Yes, the posts are submitted through AJAX and Cloudflare’s security system can’t show a nice interstitial page for submissions like that.
