Problem with the web
http://foro-disenos.epizy.com
My website was working perfectly a while ago, now it fell for no reason and I didn’t touch anything.
You can start publishing ur website…
The problem is that I already had a forum uploaded with a database, users and everything. But it disappeared out of nowhere, and in the File Manager all the files appear but it doesn’t even let me download them to be able to upload it to another website.
This is weird, are you sure the files are not uploaded within another folder?
Now everything appears except the beginning, that is, the beginning appears blank, look, I give you two links and you will see that one works and the other does not.
http://foro-disenos.epizy.com/foro/index.php?action=login
I just fixed the problem (I think)
Most likely you did not set .htaccess correctly or files not uploaded to correct folder.
Shdn’t the url be http://foro-disenos.epizy.com/index.php instead?
