Problem with SSL certificate
https://geekexcelllency.co.zw/ My SSL certificate is considered untrustworthy please help me.
You can try using Cloudflare:
See @Oxy’s post instead
@Geekexcellency
please come here https://app.infinityfree.net/ssls (step 2)
and select one of these two with a green checkmark
and not as you did before and chose self signed.
I didn’t know Self-Signed was added! There should be some sort of warning (Besides the “()”) about choosing that one. In that case, @Geekexcellency, you should follow what @Oxy said and get an SSL certificate from a trusted provider.
Thanks
@Greenreader9
this is a manual procedure for Firefox (if you need it in the future)
and then you can easily see what CERT is
click on the padlock
click on more info
2
3
