My website is not secured with SSL.
My website is secured with SSL but Arc says it’s not. How do I fix this?
Ignore it if your live widget is working.
It says it needs to be fixed to use the CDN and generate money.
Well your site does have https, so maybe contact Arc support?
Is the live widget working? I hv no issue ignoring this error so long the live widget is working and earnings are accruing.
This msg comes about is most likely due to this…
This issue is likely caused by the lack of CA chain support on free hosting. Almost all modern browser will show your website as secure, but most automatic tools, including the ones running in your own WordPress site, won’t be able to validate your SSL certificate.
For most sites this isn’t an issue. Warnings can be useful, but not if they are false positives. So unless you experience any actual issues on your website, you can just ignore that warning.
