www.samothrakisnews.gr i cant connect check it please
that im checking right now :S
Can you show me the php code in wp-config.php?
I think the code has no problem. The problem is the file location. Please check that the php file is in your htdocs folder.
is in htdocs
Both wp-settings.php and wp-config.php?
ye
That means the wp-settings.php may have problem so you cannot open it. Please also show me wp-settings.php code.
ok i take a back up older file now i have a plugin problem in line 45
code of settings ?
All the line in the php file
<?php
Used to set up and fix common variables and include
the WordPress procedural and class library.
Allows for some configuration in wp-config.php (see default-constants.php)
@package WordPress
Stores the location of the WordPress directory of functions, classes, and core content.
@since 1.0.0
define( ‘WPINC’, ‘wp-includes’ );
// Include files required for initialization.
require( ABSPATH . WPINC . ‘/load.php’ );
require( ABSPATH . WPINC . ‘/default-constants.php’ );
require_once( ABSPATH . WPINC . ‘/plugin.php’ );
These can’t be directly globalized in version.php. When updating,
we’re including version.php from another installation and don’t want
these values to be overridden if already set.
global $wp_version, $wp_db_version, $tinymce_version, $required_php_version, $required_mysql_version, $wp_local_package;
require( ABSPATH . WPINC . ‘/version.php’ );
If not already configured,
$blog_id
will default to 1 in a single site -
configuration. In multisite, it will be overridden by default in ms-settings.php.
@global int $blog_id
@since 2.0.0
global $blog_id;
// Set initial default constants including WP_MEMORY_LIMIT, WP_MAX_MEMORY_LIMIT, WP_DEBUG, SCRIPT_DEBUG, WP_CONTENT_DIR and WP_CACHE.
wp_initial_constants();
// Check for the required PHP version and for the MySQL extension or a database drop-in.
wp_check_php_mysql_versions();
// Disable magic quotes at runtime. Magic quotes are added using wpdb later in wp-settings.php.
@ini_set( ‘magic_quotes_runtime’, 0 );
@ini_set( ‘magic_quotes_sybase’, 0 );
// WordPress calculates offsets from UTC.
date_default_timezone_set( ‘UTC’ );
// Turn register_globals off.
wp_unregister_GLOBALS();
// Standardize $_SERVER variables across setups.
wp_fix_server_vars();
// Check if we have received a request due to missing favicon.ico
wp_favicon_request();
// Check if we’re in maintenance mode.
wp_maintenance();
// Start loading timer.
timer_start();
// Check if we’re in WP_DEBUG mode.
wp_debug_mode();
Filters whether to enable loading of the advanced-cache.php drop-in.
This filter runs before it can be used by plugins. It is designed for non-web
run-times. If false is returned, advanced-cache.php will never be loaded.
@since 4.6.0
@param bool $enable_advanced_cache Whether to enable loading advanced-cache.php (if present).
Default true.
if ( WP_CACHE && apply_filters( ‘enable_loading_advanced_cache_dropin’, true ) ) {
// For an advanced caching plugin to use. Uses a static drop-in because you would only want one.
WP_DEBUG ? include( WP_CONTENT_DIR . ‘/advanced-cache.php’ ) : @include( WP_CONTENT_DIR . ‘/advanced-cache.php’ );
// Re-initialize any hooks added manually by advanced-cache.php
if ( $wp_filter ) {
$wp_filter = WP_Hook::build_preinitialized_hooks( $wp_filter );
// Define WP_LANG_DIR if not set.
wp_set_lang_dir();
// Load early WordPress files.
require( ABSPATH . WPINC . ‘/compat.php’ );
require( ABSPATH . WPINC . ‘/class-wp-list-util.php’ );
require( ABSPATH . WPINC . ‘/formatting.php’ );
require( ABSPATH . WPINC . ‘/meta.php’ );
require( ABSPATH . WPINC . ‘/functions.php’ );
require( ABSPATH . WPINC . ‘/class-wp-meta-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-matchesmapregex.php’ );
require( ABSPATH . WPINC . ‘/class-wp.php’ );
require( ABSPATH . WPINC . ‘/class-wp-error.php’ );
require( ABSPATH . WPINC . ‘/pomo/mo.php’ );
// Include the wpdb class and, if present, a db.php database drop-in.
global $wpdb;
require_wp_db();
// Set the database table prefix and the format specifiers for database table columns.
$GLOBALS[‘table_prefix’] = $table_prefix;
wp_set_wpdb_vars();
// Start the WordPress object cache, or an external object cache if the drop-in is present.
wp_start_object_cache();
// Attach the default filters.
require( ABSPATH . WPINC . ‘/default-filters.php’ );
// Initialize multisite if enabled.
if ( is_multisite() ) {
require( ABSPATH . WPINC . ‘/class-wp-site-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-network-query.php’ );
require( ABSPATH . WPINC . ‘/ms-blogs.php’ );
require( ABSPATH . WPINC . ‘/ms-settings.php’ );
} elseif ( ! defined( ‘MULTISITE’ ) ) {
define( ‘MULTISITE’, false );
register_shutdown_function( ‘shutdown_action_hook’ );
// Stop most of WordPress from being loaded if we just want the basics.
if ( SHORTINIT ) {
return false;
// Load the L10n library.
require_once( ABSPATH . WPINC . ‘/l10n.php’ );
require_once( ABSPATH . WPINC . ‘/class-wp-locale.php’ );
require_once( ABSPATH . WPINC . ‘/class-wp-locale-switcher.php’ );
// Run the installer if WordPress is not installed.
wp_not_installed();
// Load most of WordPress.
require( ABSPATH . WPINC . ‘/class-wp-walker.php’ );
require( ABSPATH . WPINC . ‘/class-wp-ajax-response.php’ );
require( ABSPATH . WPINC . ‘/capabilities.php’ );
require( ABSPATH . WPINC . ‘/class-wp-roles.php’ );
require( ABSPATH . WPINC . ‘/class-wp-role.php’ );
require( ABSPATH . WPINC . ‘/class-wp-user.php’ );
require( ABSPATH . WPINC . ‘/class-wp-query.php’ );
require( ABSPATH . WPINC . ‘/query.php’ );
require( ABSPATH . WPINC . ‘/date.php’ );
require( ABSPATH . WPINC . ‘/theme.php’ );
require( ABSPATH . WPINC . ‘/class-wp-theme.php’ );
require( ABSPATH . WPINC . ‘/template.php’ );
require( ABSPATH . WPINC . ‘/user.php’ );
require( ABSPATH . WPINC . ‘/class-wp-user-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-session-tokens.php’ );
require( ABSPATH . WPINC . ‘/class-wp-user-meta-session-tokens.php’ );
require( ABSPATH . WPINC . ‘/class-wp-metadata-lazyloader.php’ );
require( ABSPATH . WPINC . ‘/general-template.php’ );
require( ABSPATH . WPINC . ‘/link-template.php’ );
require( ABSPATH . WPINC . ‘/author-template.php’ );
require( ABSPATH . WPINC . ‘/post.php’ );
require( ABSPATH . WPINC . ‘/class-walker-page.php’ );
require( ABSPATH . WPINC . ‘/class-walker-page-dropdown.php’ );
require( ABSPATH . WPINC . ‘/class-wp-post-type.php’ );
require( ABSPATH . WPINC . ‘/class-wp-post.php’ );
require( ABSPATH . WPINC . ‘/post-template.php’ );
require( ABSPATH . WPINC . ‘/revision.php’ );
require( ABSPATH . WPINC . ‘/post-formats.php’ );
require( ABSPATH . WPINC . ‘/post-thumbnail-template.php’ );
require( ABSPATH . WPINC . ‘/category.php’ );
require( ABSPATH . WPINC . ‘/class-walker-category.php’ );
require( ABSPATH . WPINC . ‘/class-walker-category-dropdown.php’ );
require( ABSPATH . WPINC . ‘/category-template.php’ );
require( ABSPATH . WPINC . ‘/comment.php’ );
require( ABSPATH . WPINC . ‘/class-wp-comment.php’ );
require( ABSPATH . WPINC . ‘/class-wp-comment-query.php’ );
require( ABSPATH . WPINC . ‘/class-walker-comment.php’ );
require( ABSPATH . WPINC . ‘/comment-template.php’ );
require( ABSPATH . WPINC . ‘/rewrite.php’ );
require( ABSPATH . WPINC . ‘/class-wp-rewrite.php’ );
require( ABSPATH . WPINC . ‘/feed.php’ );
require( ABSPATH . WPINC . ‘/bookmark.php’ );
require( ABSPATH . WPINC . ‘/bookmark-template.php’ );
require( ABSPATH . WPINC . ‘/kses.php’ );
require( ABSPATH . WPINC . ‘/cron.php’ );
require( ABSPATH . WPINC . ‘/deprecated.php’ );
require( ABSPATH . WPINC . ‘/script-loader.php’ );
require( ABSPATH . WPINC . ‘/taxonomy.php’ );
require( ABSPATH . WPINC . ‘/class-wp-taxonomy.php’ );
require( ABSPATH . WPINC . ‘/class-wp-term.php’ );
require( ABSPATH . WPINC . ‘/class-wp-term-query.php’ );
require( ABSPATH . WPINC . ‘/class-wp-tax-query.php’ );
require( ABSPATH . WPINC . ‘/update.php’ );
require( ABSPATH . WPINC . ‘/canonical.php’ );
require( ABSPATH . WPINC . ‘/shortcodes.php’ );
require( ABSPATH . WPINC . ‘/embed.php’ );
require( ABSPATH . WPINC . ‘/class-wp-embed.php’ );
require( ABSPATH . WPINC . ‘/class-oembed.php’ );
require( ABSPATH . WPINC . ‘/class-wp-oembed-controller.php’ );
require( ABSPATH . WPINC . ‘/media.php’ );
require( ABSPATH . WPINC . ‘/http.php’ );
require( ABSPATH . WPINC . ‘/class-http.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-streams.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-curl.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-proxy.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-cookie.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-encoding.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-response.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-requests-response.php’ );
require( ABSPATH . WPINC . ‘/class-wp-http-requests-hooks.php’ );
require( ABSPATH . WPINC . ‘/widgets.php’ );
require( ABSPATH . WPINC . ‘/class-wp-widget.php’ );
require( ABSPATH . WPINC . ‘/class-wp-widget-factory.php’ );
require( ABSPATH . WPINC . ‘/nav-menu.php’ );
require( ABSPATH . WPINC . ‘/nav-menu-template.php’ );
require( ABSPATH . WPINC . ‘/admin-bar.php’ );
require( ABSPATH . WPINC . ‘/rest-api.php’ );
require( ABSPATH . WPINC . ‘/rest-api/class-wp-rest-server.php’ );
require( ABSPATH . WPINC . ‘/rest-api/class-wp-rest-response.php’ );
require( ABSPATH . WPINC . ‘/rest-api/class-wp-rest-request.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-posts-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-attachments-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-post-types-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-post-statuses-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-revisions-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-autosaves-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-taxonomies-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-terms-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-users-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-comments-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-search-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-blocks-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-block-renderer-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-settings-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/endpoints/class-wp-rest-themes-controller.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-comment-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-post-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-term-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/fields/class-wp-rest-user-meta-fields.php’ );
require( ABSPATH . WPINC . ‘/rest-api/search/class-wp-rest-search-handler.php’ );
require( ABSPATH . WPINC . ‘/rest-api/search/class-wp-rest-post-search-handler.php’ );
require( ABSPATH . WPINC . ‘/class-wp-block-type.php’ );
require( ABSPATH . WPINC . ‘/class-wp-block-type-registry.php’ );
require( ABSPATH . WPINC . ‘/class-wp-block-parser.php’ );
require( ABSPATH . WPINC . ‘/blocks.php’ );
require( ABSPATH . WPINC . ‘/blocks/archives.php’ );
require( ABSPATH . WPINC . ‘/blocks/block.php’ );
require( ABSPATH . WPINC . ‘/blocks/categories.php’ );
require( ABSPATH . WPINC . ‘/blocks/latest-comments.php’ );
require( ABSPATH . WPINC . ‘/blocks/latest-posts.php’ );
require( ABSPATH . WPINC . ‘/blocks/shortcode.php’ );
$GLOBALS[‘wp_embed’] = new WP_Embed();
// Load multisite-specific files.
require( ABSPATH . WPINC . ‘/ms-functions.php’ );
require( ABSPATH . WPINC . ‘/ms-default-filters.php’ );
require( ABSPATH . WPINC . ‘/ms-deprecated.php’ );
// Define constants that rely on the API to obtain the default value.
// Define must-use plugin directory constants, which may be overridden in the sunrise.php drop-in.
wp_plugin_directory_constants();
$GLOBALS[‘wp_plugin_paths’] = array();
// Load must-use plugins.
foreach ( wp_get_mu_plugins() as $mu_plugin ) {
include_once( $mu_plugin );
Fires once a single must-use plugin has loaded.
@since 5.1.0
@param string $mu_plugin Full path to the plugin’s main file.
do_action( ‘mu_plugin_loaded’, $mu_plugin );
unset( $mu_plugin );
// Load network activated plugins.
foreach ( wp_get_active_network_plugins() as $network_plugin ) {
wp_register_plugin_realpath( $network_plugin );
include_once( $network_plugin );
Fires once a single network-activated plugin has loaded.
@since 5.1.0
@param string $network_plugin Full path to the plugin’s main file.
do_action( ‘network_plugin_loaded’, $network_plugin );
unset( $network_plugin );
Fires once all must-use and network-activated plugins have loaded.
@since 2.8.0
do_action( ‘muplugins_loaded’ );
ms_cookie_constants();
// Define constants after multisite is loaded.
wp_cookie_constants();
// Define and enforce our SSL constants
wp_ssl_constants();
// Create common globals.
require( ABSPATH . WPINC . ‘/vars.php’ );
// Make taxonomies and posts available to plugins and themes.
// @plugin authors: warning: these get registered again on the init hook.
create_initial_taxonomies();
create_initial_post_types();
wp_start_scraping_edited_file_errors();
// Register the default theme directory root
register_theme_directory( get_theme_root() );
// Load active plugins.
foreach ( wp_get_active_and_valid_plugins() as $plugin ) {
wp_register_plugin_realpath( $plugin );
include_once( $plugin );
Fires once a single activated plugin has loaded.
@since 5.1.0
@param string $plugin Full path to the plugin’s main file.
do_action( ‘plugin_loaded’, $plugin );
unset( $plugin );
// Load pluggable functions.
require( ABSPATH . WPINC . ‘/pluggable.php’ );
require( ABSPATH . WPINC . ‘/pluggable-deprecated.php’ );
// Set internal encoding.
wp_set_internal_encoding();
// Run wp_cache_postload() if object cache is enabled and the function exists.
if ( WP_CACHE && function_exists( ‘wp_cache_postload’ ) ) {
wp_cache_postload();
Fires once activated plugins have loaded.
Pluggable functions are also available at this point in the loading order.
@since 1.5.0
do_action( ‘plugins_loaded’ );
// Define constants which affect functionality if not already defined.
wp_functionality_constants();
// Add magic quotes and set up $_REQUEST ( $_GET + $_POST )
wp_magic_quotes();
Fires when comment cookies are sanitized.
@since 2.0.11
do_action( ‘sanitize_comment_cookies’ );
WordPress Query object
@global WP_Query $wp_the_query
@since 2.0.0
$GLOBALS[‘wp_the_query’] = new WP_Query();
Holds the reference to @see $wp_the_query
Use this global for WordPress queries
@global WP_Query $wp_query
@since 1.5.0
$GLOBALS[‘wp_query’] = $GLOBALS[‘wp_the_query’];
Holds the WordPress Rewrite object for creating pretty URLs
@global WP_Rewrite $wp_rewrite
@since 1.5.0
$GLOBALS[‘wp_rewrite’] = new WP_Rewrite();
WordPress Object
@global WP $wp
@since 2.0.0
$GLOBALS[‘wp’] = new WP();
WordPress Widget Factory Object
@global WP_Widget_Factory $wp_widget_factory
@since 2.8.0
$GLOBALS[‘wp_widget_factory’] = new WP_Widget_Factory();
WordPress User Roles
@global WP_Roles $wp_roles
@since 2.0.0
$GLOBALS[‘wp_roles’] = new WP_Roles();
Fires before the theme is loaded.
@since 2.6.0
do_action( ‘setup_theme’ );
// Define the template related constants.
wp_templating_constants();
// Load the default text localization domain.
load_default_textdomain();
$locale = get_locale();
$locale_file = WP_LANG_DIR . “/$locale.php”;
if ( ( 0 === validate_file( $locale ) ) && is_readable( $locale_file ) ) {
require( $locale_file );
unset( $locale_file );
WordPress Locale object for loading locale domain date and various strings.
@global WP_Locale $wp_locale
@since 2.1.0
$GLOBALS[‘wp_locale’] = new WP_Locale();
WordPress Locale Switcher object for switching locales.
@since 4.7.0
@global WP_Locale_Switcher $wp_locale_switcher WordPress locale switcher object.
$GLOBALS[‘wp_locale_switcher’] = new WP_Locale_Switcher();
$GLOBALS[‘wp_locale_switcher’]->init();
// Load the functions for the active theme, for both parent and child theme if applicable.
foreach ( wp_get_active_and_valid_themes() as $theme ) {
if ( file_exists( $theme . ‘/functions.php’ ) ) {
include $theme . ‘/functions.php’;
unset( $theme );
Fires after the theme is loaded.
@since 3.0.0
do_action( ‘after_setup_theme’ );
// Set up current user.
$GLOBALS[‘wp’]->init();
Fires after WordPress has finished loading but before any headers are sent.
Most of WP is loaded at this stage, and the user is authenticated. WP continues
to load on the {@see ‘init’} hook that follows (e.g. widgets), and many plugins instantiate
themselves on it for all sorts of reasons (e.g. they need a user, a taxonomy, etc.).
If you wish to plug an action once WP is loaded, use the {@see ‘wp_loaded’} hook below.
@since 1.5.0
do_action( ‘init’ );
// Check site status
if ( true !== ( $file = ms_site_check() ) ) {
require( $file );
die();
unset( $file );
This hook is fired once WP, all plugins, and the theme are fully loaded and instantiated.
Ajax requests should use wp-admin/admin-ajax.php. admin-ajax.php can handle requests for
users not logged in.
@since 3.0.0
do_action( ‘wp_loaded’ );
I doubt that this is a configuration issue, but rather an issue with missing websites. Maybe following this guide helps to fix them?
https://infinityfree.net/support/how-to-fix-a-corrupted-wordpress-installation/
the new wordpress installation not work, i use an old backup copy of my site and now work just now need to update it again. im not lost evrything anyway. thanks your help all
