Problem while connecting to extention
cURL error 60: SSL certificate problem: unable to get local issuer certificate.
could anyone tell my what is this issue i am having and how can solve this?
Is this a support question? If so, why is it in the Informal category?
corrected…kindly tell me what is this issue
As i am using the ssl certificate which i generated here and installed into my site. I dont know why am I having this issue
When and where do you see this error?
while connecting my plugin.
kindly help
php.ini where can i get this file?
The php.ini file is inaccessible on free shared hosting, as it contains settings for all users on the server.
if it isnt.
then how can i resolve my issue?
anyother way to solve this issue as i shown above
SSL errors when using automated tools are unfortunately a consequence of how the SSL installation setup works on free hosting. To fix this, you can either use Cloudflare on your domain name or move to premium hosting.
