Problem when installing tagdiv composer plugins
Hi i have installed newspaper 8 wordpress theme, but when i install this tagdiv composer plugin in Wordpress it shows Ajax error.
You’ll probably want to contact the plugin vendor for support about it.
I checked your domain name and I see you’re using Cloudflare. If you’re using Cloudflare’s Flexible SSL, please make sure your website is set up like so:
https://infinityfree.net/support/wordpress-and-cloudflare-flexible-ssl/
Many people use the “Automatic HTTPS Rewrites” option to make their website “work” with Cloudflare, but that option combined with WordPress tends to result in weird error like this.
